Club smart car
> How-To: Remove Cabriolet Headliner for Cleaning
Mike T
post Nov 13 2006 - 02:36 PM
Post #1
'Floating' Director of CsC
Group: Moderators
My headliner was filthy as will be most cabrio owners' headliners, because when the car is driven with the top down, it catches the wind and filters any dirt that is in the air, trapping it in the light coloured fabric.
So how is it removed?
You start by releasing the very end at the back of the car. Open the tailgate, flip up the rear window and dig your fingernails into the hard plastic ridge at the end of the headliner, on either the left or right side, pulling it gently out of the slot in the black plastic panel, into which it is embedded. Work gently from one side to the other.
Note: this rear part is not held in by a barbed clip or anything that is difficult to release; it is a friction fit only.
Attached File(s)
2006 smart BRABUS Canada 1 cabriolet 450: Snowball (BRABUS Tailor Made, leather/Alcantara, OE cruise)
2005 smart cdi pulse cabriolet 450: Rana smartii, "smart frog" (green/black/blue cloth, OE cruise, strikeline)
2008 Mercedes-Benz B 200: The family car, small outside and massive inside: a solid, comfy reliable car!
1966 Peugeot 404 Coupé Injection: A nice Pininfarina classic with Kugelfischer mechanical fuel injection
Go to the top of the page
+Quote Post
Mike T
post Nov 13 2006 - 02:48 PM
Post #2
Group: Moderators
After the rear is released, it's time to open the roof to about the 1/3 open position. You need to be able to see the inner framework, where the headliner rails attach to the metal roof struts that lie transversely across the fabric roof.
The headliner is bonded ans sewn to long plastic U-shaped channels at the points where you can see transverse stitching from the underside, and these U-shaped channels are clipped onto the metal struts.
The U-channels run the entire width of the headliner. They are not just little clips on one end or the other.
So with the roof partly open, take a blade screwdriver and jam it gently into the space between the U-channel plastic and the metal roof strut, on the strut nearest the rear window. Twist the blade slightly until the first part of the U-channel is released. Do the same on the other side, until one of the ends is completely released for a couple of cm. Then stick your fingers in and pull downwards on the plastic U-channel across the width of the car, working from the side you started on to the opposite side. Be firm, because the headliner's U-channels are clipped on very tightly, and the metal roof struts are robust so you can crank on it if you have to.
Attached File(s)
+Quote Post
Mike T
post Nov 13 2006 - 02:57 PM
Post #3
Group: Moderators
Once you have released one of the U-channels, the others are all done in a similar fashion, so just repeat the process another 5 times.
Attached File(s)
+Quote Post
Mike T
post Nov 13 2006 - 03:01 PM
Post #4
Group: Moderators
Third U-channel - it's the same as the frst, you will be getting more efficient at this point....
The other three drop like flies and then you have the whole headliner hanging only by the front attachment!
Attached File(s)
+Quote Post
Mike T
post Nov 13 2006 - 03:07 PM
Post #5
Group: Moderators
So with the headliner hanging by the frontmost attachment only, all you need to do is release the friction-fit clips. I did the centre portion first, which is identical to the rearmost attachment of the headliner.
But on the front, there are two clips on either lateral extremity, which must be released separately. You will need the screwdriver to do this. Gently pry them out from the underside of the headliner.
Presto, you're done!
Attached File(s)
+Quote Post
Mike T
post Nov 13 2006 - 03:10 PM
Post #6
Group: Moderators
Lying on the hood of my 404 C, maybe you can see how dirty it is....
The underside shows the foam insulation that is bonded to the fabric, and the U-channels.
Attached File(s)
+Quote Post
Mike T
post Nov 13 2006 - 03:13 PM
Post #7
Group: Moderators
So for cleaning, I put mine in the bathtub and used laundry detergent and a fingernail brush to get the dirt out. It was about 99% effective.
Although I have not done it yet (headliner is drip-drying as I write this), re-installation of the headliner will be the reverse of removal, working from the front to the back of the car.
+Quote Post
Diesel Dave
post Nov 13 2006 - 08:26 PM
Post #8
Group: Regular Members
2006 smart fortwo passion cabriolet, silver/scratch black, bungee grey interior, A/C, softouch, locking under seat drawer, storage compartment cover, power heated mirrors, speed sensitive wipers, drive lock, smart sound package, clock & rev counter, drivers vanity mirror, velour floormats, coreline wheels and wide tires, brabus spoiler, s-mann intake scoop, K&N filter, delipped intake, Technine Tuning Stage II re-map, keyless power windows, front mudflaps, Fiamm air horns, Euro spec fenders and lighting, HID headlights and foglights, Garmin navigation system.
+Quote Post
I M SMRT
post Nov 13 2006 - 08:57 PM
Post #9
Group: Moderators
do you think spraying some sort of protectant may help keep it cleaner?
S
2006 Grandstyle Fortwo #23/200
O ||||||| O 2007 Jeep Wrangler Unlimited
There are two types of pedestrians in this world. The quick and the dead.
+Quote Post
Mike T
post Nov 13 2006 - 09:59 PM
Post #10
Group: Moderators
No it diidn't shrink. I dried it in our shower stall this afternoon and just re-installed it in the car an hour ago. Perfect fit, and perfectly clean!
Re-installation is a lot easier than removal because everything just snaps easily into place. If the U-channels are not centred properly on the roof struts, it's not a problem, because they can be slid from side to side easily once installed. Re-installation took me about three minutes.
There would be no point in Scotchgarding it because it'll still get dirty, and the only way to clean it thoroughly is to remove it! Right Muriel? wink.gif
+Quote Post
Duck
post Nov 14 2006 - 05:39 AM
Post #11
Crazy Quacker
Great resource and an interesting read! Pretty amazing how complex the whole folding roof system is on the cab's.
-Iain
Nosedive.... 285 000 km+
+Quote Post
ianjay
post Nov 14 2006 - 07:07 AM
Post #12
Greetings:
Thanks for doing such an excellent job describing the process!
Cheers,
Ian Jay
'05 Pulse stream green/black tridion cabrio, a/c (?), fanfare, CD changer, Loblaws beach towels (smiley serpents or smiley faces) on seats, "GOTSMART" plates, ordered Sept '04, delivered Feb '05
+Quote Post
smartzuuk
post Nov 14 2006 - 10:57 PM
Post #13
Efficiency Matters
Group: Moderators
Gee, I need a new car so I can practice that routine.
+Quote Post
Mike T
post Nov 16 2006 - 09:20 PM
Post #14
Group: Moderators
Be careful when re-installing to tuck any excess fabric (that is slightly loose from the plastic tongue of the leading edge of the headliner) into the black plastic groove.
A thin plastic card, thinner than a credit card, would be especially suitable to help with this "tucking in" procedure. Failing that, a business card.....
If you don't take care at this stage, the leading edge of the headliner may look ragged after re-installation.
+Quote Post
For2
post Dec 23 2007 - 05:29 PM
Post #15
Yesterday I finally remembered and had time to remove our headliner, following Mike's instructions.
The instructions were easy to follow and removed without problems.
We successfully scrubbed it in the bathtub with ivory dish soap, some color safe powdered bleach and a soft brush.
Then hung it to dry overnight.
I put in back in this afternoon and it really looks great.
This procedure works wonders and we will be doing this every fall after having the cabrio top down all summer. thumbsup_anim.gif
2005 Fortwo Passion Cabrio cdi with Silver Tridion, NUMERIC BLUE (EU) Panels & Power Mirrors. Black Leather Heated Seats & Storage Drawer, A/C, Power Steering, Soft Touch, Complete with Clock & Rev Counter, Sound Package and Vanity Mirrors. Now with Upgraded Horn, Wheel Locks, Aluminum Blue Suspension Caps, Driver Footrest, Ignition Free Window Module, Blue LED Interior Light, Euro Side Markers, Interior Wind Blocker, Cruise Control, a TENT TRAILER, Valve Stem Caps, & Scan Gauge. More to come!
+Quote Post
leejor
post Dec 24 2007 - 03:48 PM
Post #16
Sounds like someone need to design, make,and perhaps market, a cover to protect the top from dirt when folded down.
+Quote Post
Mike T
post Nov 29 2008 - 07:16 PM
Post #17
Group: Moderators
And two years on I have washed it again. It's still coming out clean, so that's good. Removing it can be done without the steps described at the beginning of this thread, if you have strong fingers and a high pain threshold wink.gif
+Quote Post
SameGuy
post Nov 30 2008 - 06:34 AM
Post #18
Group: Moderators
Thanks again! My first cleaning will be later this week, when I do a between-services service (winterizing and adjusting). Hopefully the cruise wiper stalks will be in shortly, too.
Francesco
2006 fortwo cdi pulse cabrio phat red/silver|heated leather|PLUS|sound|rack||mods LED slices|OE cruise|no front plate|keyless windows|EU lights front & rear|OE mud-flaps|colour-code|garage opener|wiper nozzle|Alpine|SGII|remap|Mocal adapter|K&N|RS grille|suspension caps|Hella fogs|Michalak sucker|mirror caps|door pulls|EBC discs & pads|TK's cooling system plug|LED angel eyes||coming up Wolo 417 air horn|Blindy||wishlist Optigear paddles|sixteens|more leather||
+Quote Post
0 Members:
Lo-Fi Version Time is now: Sep 3 2010 - 07:59 AM
